Battery Power Question
idoc
May 16, 2007
I have what I believe is an unusual problem. I am sitting in my kitchen with 50% battery power left on my iPhone. I attempt to make a call with barely 1 bar of signal power and every call fails. I attach the sync cable to my computer as if I were going to sync and my signal bars go up to 3 & 4 and every call goes through. I haven't moved. Is it possible that a 50% batter is not enough to power the phone? Thanks for you help.
petalmom
Jun 30, 2007
494
I'm not sure that's what's causing your problem. My battery is frequently below 50% and the phone works fine.
seb481
Aug 3, 2007
774
San Diego
No but I think that plugin your iPhone increases the antenna strength
iLLGT2
Jul 26, 2007
211
NY/LI
Ive used my phone at under 20% with no issues like that!
spankbot
Sep 6, 2007
106
It's normal. Welcome to the wonderful world of cell phones.
iPastor
Aug 10, 2007
95
Virginia
www.myspace.com
I agree, your cable is acting as an antenna when you plug it in. I'd be willing to bet if you further the experiment by unplugging your phone and walking to a point where you have 4 bars or so with less than 50% battery you'll find that it makes calls just fine... it's the signal strength not the battery I believe. :)
