battery what?
Radis
Jul 3, 2007
173
so i keep hearing about your batter glowing when it gets done charging, mine doesn't, is that a bad thing?
and i don't have the option of turning my phone to auto check the mail, so i don't know if that is wrong and should return it and get a different on, or what. please help thanks
Britna
278
30
Try charging it, until it's "full", then take it off the charger and put it back on... That usually does the trick for me.
dsuppa
Jul 3, 2007
208
New Jersey
www.dfsdesigns.com
The way I have to do it is Charge the battery over night with the wall charger, then sync with my laptop. This is the only way I get the glowing battery and reset my usage statistics.
alb0zf1n3st
Jul 2, 2007
624
No point in doing all that on like a daily basis sometimes just to see a glowing battery lol
TrippalHealicks
Mar 2, 2007
1,341
Which email provider are you using? Is it Yahoo? Gmail?
dsuppa
Jul 3, 2007
208
New Jersey
www.dfsdesigns.com
I sync my iPhone pretty much every morning anyway to put on new shows/movies I converted the previous night. Plus this resets the Usage Statistics for me so it's helpful. But if I'm not adding anything to the iPhone I don't sync just to get the glowing battery, lol.
ColsTiger
Mar 8, 2007
5,856
Columbus, GA
No one has the option to auto-check the mail. It does that when you select the Mail icon.
The only mail that is delivered directly to your iPhone is yahoo push email.
dsuppa
Jul 3, 2007
208
New Jersey
www.dfsdesigns.com
You can set your phone to check your email automatically every 15 minutes - 1 hour. Not sure if thats the same thing your talking about, but it works for me and I don't have to go into my mailbox to check mail.
ColsTiger
Mar 8, 2007
5,856
Columbus, GA
I thought he was saying to automatically notify you immediately when an email comes in.
