Best Cache Cleaning app
Nov 8, 2014
50
So...brand new to these forums. Have been on the 6 plus for about a week...what are the best app cache cleaning apps available?
radtechy
Jul 20, 2011
496
41
As far as I know just double pressing the home button and swiping up the apps does just fine
silvermoon
Jul 17, 2013
1,624
179
Washington
Welcome to the forums, hope you stay awhile. Back to your question, I wouldn't recommend any sort of app or cache cleaning for your 6+. As iOS does a good job of managing all of this for you, it's not necessary to install extra apps. You can delete apps that you don't use if you are trying to free up storage.
silvermoon
Jul 17, 2013
1,624
179
Washington
I would only swipe up on apps if you are having an issue with them or they become unresponsive. Since iOS is handling all of this for you, it's possible to slow down your phone if you constantly close down apps.
rugved1118
Sep 27, 2013
644
Hello,
Can you please elaborate on this ? If swiping the apps by pressing the home button frequently will slow down the phone, then how should we close them ? Not closing the apps would eat up more battery... Right ? I am sorry but trying to figure out what you have posted.
Sent from my iPhone 5S
Ledsteplin
Oct 29, 2013
4,841
997
65
Florence, AL
Hello,
Closing apps actually use more battery resources. It takes a lot to start them back up. There's not really any good apps for clearing cache from apps. Apple has pulled them from the App Store. The best way is to delete the app, then reinstall it.
Sent from my ancient but trustworthy iPhone 5.
rugved1118
Sep 27, 2013
644
In that case, then why would anyone suggest to close apps to save battery ? So, you mean if i use 10 apps daily, does that mean i should never close them ?
silvermoon
Jul 17, 2013
1,624
179
Washington
I'll try. The point that I was trying to make is you should not get into the habit of force closing apps. iOS will actually disable inactive apps and so they should not take up any battery power. As Led was also saying, it is a strain on the phone when you constantly open and close apps. I was suggesting that you only do this if it is really necessary, such as in the case of an app freezing or not wanting to respond. If you are looking to save battery, there are other things you can do that don't involve closing apps such as checking what apps are set to run in the background and then decide if you need them to stay open in the background. You can disable disable services that are consuming battery power. I don't think that closing apps is the best way to speed up your phone.
rugved1118
Sep 27, 2013
644
Thanks. My concept is clear now.
ZR_Yancy
Jul 11, 2008
3,982
737
Whatever happened to CM Security app? Was that removed from the Appstore again?
Ledsteplin
Oct 29, 2013
4,841
997
65
Florence, AL
Who suggests that?
Ledsteplin
Oct 29, 2013
4,841
997
65
Florence, AL
I don't think it came back. iTunes did not like their method of pushing cache from apps. Basically, they filled up the phone's available space, thereby pushing the cache out. Or something to that effect.
ZR_Yancy
Jul 11, 2008
3,982
737
I guess I'm confused with the Android version.
rugved1118
Sep 27, 2013
644
What about battery doctor app which claim to clean up junk ?
Ledsteplin
Oct 29, 2013
4,841
997
65
Florence, AL
Probably a waste of time. If you think you're getting too much "other" taking up all your phone's storage space, just restore as new.
Ledsteplin
Oct 29, 2013
4,841
997
65
Florence, AL
There's nothing in the description to indicate this app purges cache. What does it do to give you more storage space? It looks to me it's just another battery app that shows battery stats and charging info.
mrbunglez
Mar 20, 2008
439
100
43
It deletes stored cache. And frees up memory as well. Here's some pics of it.
silvermoon
Jul 17, 2013
1,624
179
Washington
How can I tell which apps are running in the backgrounc?
Double press the home key to see which apps are running. You could also take a look at Background App Refresh to see which apps you have set to refresh in the background.
