Best Cydia Themes
iphonewarrior
13,847
702
#21
i got this too, is there an easy way to use my own wallpaper. the "user wallpaper" option in winterboard doesn't work for me
Did you also install WeatherFurikI0S4? What I did was ssh into my phone and replaced the wallpaper.png file located in the WeatherFurikI0S4 folder.
Stapes, you are right, just SSH into the Themes folder, then into said theme and delete the Wallpaper.png file and respring.
stapes
Oct 3, 2007
#22
Yes , what iPhonewarrior said.... By the way thx for the step by step walk though on how to tweak the 2 files located inside WeatherFurikI0S4 so that I'm able to display the correct City : )
iphonewarrior
13,847
702
#23
No problem :eek:k:eek:k
Krunk83
Jun 28, 2008
4,605
#24
GreyHD is one of my favorites from Cydia and I don't usually theme my phone these days. I randomly found it and it's really nice I think. I'll post a pic later.
BlindSpoTT
Dec 16, 2008
1,092
York, PA
#25
i got it now, i just used iFile and chandge the wallpaper name in the themes folder.
stapes
Oct 3, 2007
#26
Here is another theme....though its not free and I tweaked it to my liking. Them is called NineHD. Once again I used WeatherFurikI0S4 to display my local weather.
iphonewarrior
13,847
702
#29
Yes you can theme an iPhone 3G. It runs quite slow, though.
5,580
#31
goldenglove_21, check post #21.
stapes
Oct 3, 2007
#32
I just keep changing my theme daily.... BUT I think I finally found one that might stick around for a bit. I installed Classified HD and a nifty weather widget.
Krunk83
Jun 28, 2008
4,605
#36
6 Status Bar Battery Colors in Cydia. Activate colors through Winterboard.
Watcher
Mar 29, 2009
1,785
30
Phoenix, AZ
#40
In case anyone wanted the green biteSMS icons for the GreyHD theme, here they are: :eek:k:eek:k
