Best hard drive for my MacBook Pro?
Veevee
Apr 22, 2013
20
I'm looking to back up my macbook onto a hard drive ( my music and pictures mostly) and also need to transfer just my pictures and music from one mac to the other as well as backing up my new mac ... which hard drive is best for my macbook pro- a portable or external ? also is any brand in specific to get? what would u recommend and not recommend .. thanks!
silvermoon
Jul 17, 2013
1,624
179
Washington
You can just use an external hard drive which will plug in via USB. Seagate makes a Backup Plus Slim in a 1TB and 2TB. Western Digital has one with built in security. Portable is external as the other kind would be internal.
llrickman
Jan 12, 2008
787
26
Albuquerque , NM
My 1 and 2tb my books are external hd. I have a small hd 500 or so gb that is solid state that is portable
I think that may be what the op meant
I wouldn't wanna be carrying around those my books as they are kinda big plus they have a standard hard drive which would be much easier to corrupt if your moving it around all the time
But I have had them for sometime. I really wanna get a large sshd for my MacBook for backups but they are still pricey
