Best plan for Tmobile unlocked iPhone?
wildturkey
Aug 14, 2007
168
Does anyone know what the best and what data features i need not to get rapped?
kenny
Nov 24, 2007
use the blackberry data plan. $20 iirc. Good luck
themanofthedark
Jan 5, 2008
2,674
25
Boston
not even. use the 5.99 plan, its the same result, only $14 less.
get a fave5 plan, though, definitaly, because otherwise you will BURN through your minutes.
most plans, tmo to tmo is free, as are nights and weekends..
t-mobile > Att
