Best turn-by-turn GPS?
15,385
1,023
I know this is an old discussion, so bear with me. I've done a bit of research and am now looking for some more hands-on feedback.
I'm in a new area now, and kinda need a better GPS solution than Google maps or MapQuest. Mapquest was OK back home, but in DC, it is not very accurate at all. The routes it plots are not very pratcical, and it will often get me into the general area of my destination, but not TO my destination. So the main goal is to get something more accurate than MapQuest, and has live traffic updating and locally stored maps. iPhone and iPad compatibility would be a bonus, but not a dealbreaker. Cost isn't a big issue as long as the functionality is there.
AT&T Navigator and TomTom look like my best bets so far - any feedback on those?
Bennyboy
Jul 21, 2010
14,017
1,731
PA
The only beef I have with navigon is that its always 200-500 ft short of my destination. Maybe not always but 80% of the time, other than that Ive never had any problems with it.
Also the entering of addresses could be smoothed out a bit.
I use the app "around me" to search whatever I'm looking for and it gives you either the google maps or the navigon option, very handy.
I'm all about the one time fee, if that's what you're looking for then navigon is where it's at.
  • Like
Reactions: acosmichippo
chris
Administrator
Administrator
Jun 10, 2006
11,817
1,707
Long Island, NY
I had trouble with Navigon for months. It would shift into some sort of augmented reality mode. When I switched iPhones, it started working and now I'm going to eBay the Garmin 1450 I purchased.
Last time I checked, the prices on Navigon were low $20-$30. I highly recommend it. It's been great, especially living in a new area.
  • Like
iphonewarrior
13,847
699
I second/third Navigon, it's very good at what it does. There is a sister app which allows you to search via postal code as well.
In my opinion it's better than TomTom.
  • Like
Rugaby
Feb 18, 2011
7,122
1,172
Washington state
If I am close to a location I look it up on google maps an look at the list. If I need turn by turn I live by AT&T navigation. Plus AT&T navigation is awesome for finding things. Cheapest gas near your location food by type.
15,385
1,023
I'm leaning toward AT&T right now if only for the fact that I can try it for a month for only $10.
rom x
Jan 18, 2011
1,048
99
I may not use my gps everyday like a pizza delivery guy, but I do use it a lot. Atleast 2-3 times a week. And I have had a tom tom, navagon, and 2 garmins. And let me just say that now I use a telenav. And have since given away my garmin to my son. The telenav gps app that is on my phone now is the best nav app I have ever used thus far. I like the way you don’t have to input the complete address just start typing the addy and the app starts to give you suggestion and they are almost always the one your are looking for. So you don’t even have to have the correct spelling and your address comes up. It also has traffic alerts. And as you come closer to your streets they pop up 3d like so it’s real easy to read while driving.
http://itunes.apple.com/us/app/gps-by-telenav/id414817704?mt=8&ign-mpt=uo=2
Jmbaker429
Jun 28, 2010
994
144
34
I have always used the Magellan Roadmate app on my iPhones. Always had great luck with them and it's always worked perfect for me. I use it most everyday on the job.
15,385
1,023
Ok, AT&T navigator (which is essentially telenav) is horrible. I live really close to an expensive toll road, so pretty much any route I set in ATTN uses it. I will not use that road just because I can't afford to every single day. Even beyond that, I can't seem to figure out how it does traffic updating, and I got caught in a huge jam this morning without it directing me to alternate side roads (which I eventually did on my own with google maps).
I guess I'll try navigon next, but before I bite the bullet, can anyone confirm that I can specify to not use toll roads? If not, it would be useless to me. Live adjustment of the route based on traffic is also a big feature I need. My mom's standalone Tom Tom does both of these, so I imagine at least some of these apps can too.
Apps this expensive really need a trial period of some sort...
I also recommend using it in conjunction with the Around Me app. My only complaint with Navigon is that it doesn't have a built-in search (similar to the Maps app) and the method of inputting addresses. Around Me fixes that because you can use it to search and then tap "Route" and select Navigon. It will then automatically open Navigon (or Tom Tom). The jailbroken app Navigate from Maps is even better (because it plugs into the stock maps app), but Around Me works just fine if you're stock.
15,385
1,023
Thanks for all the recommendations, everyone. Haven't given it a proper shakedown yet, but it looks good playing with it at my desk.
That's what she said.
