Best way to install InvisibleShield?
Nemss316
Jun 17, 2008
435
St. Louis, MO
I'm looking to replace my current case on my iPhone. I forgot how great it looked without the case, and decided to get the invisible shield.
For those of you that have it on, I've seen the video, but of course, applying something can never be that easy! :cool:
So, is there any extra tips, or tricks that you can pass along to me?
Thanks,
Jason
Rip
Oct 23, 2007
636
Northern England
Spray on as much of the application spray as you think you'll need onto the shield - and then double it!
I've done a few of these now and get better each time.
Definitely leave it for a full 24 hours before using.
Cleanliness is paramount.
Apply it and the put it aside for 1/2 an hour. Then work the bubbles and edges again. Repeat until perfect every 1/2 hour or so and you can get it perfect.
Rip
Oct 23, 2007
636
Northern England
I should add to pay special attention to the corners and edges. Keep on working them until they stick.
I'm on my second one for my 3G (first one was the mark one, second version is much better - got a free replacement).
I really is 'invisible' (well almost).
There's obviously a different feel but it is more grippy.
I just put mine in my pocket with keys and change and don't worry about it.
After removing the first version the thing was still like new. Very impressed.
I've now got them on both a Macbook and Macbook Pro.
