Best Way To Upgrade?
Bobby Digital
Jul 15, 2007
I currently have the original 1.1.1 firmware. I want to upgrade but will I lose everything that I have installed. is there a way to upgrade to 1.1.2 without losing the stuff that I have downloaded?
6,682
49
not really. Everytime you update the firmware, it wipes out the installer.
Since you are on 1.1.1, this is what I recommend:
1) write down everything that shows in the uninstall section of installer and under Sources
2) Locate and install the OkToPrep app. This will prepare you for jailbreaking 1.1.2
3) download the 1.1.2 jailbreak.zip package and unzip it to a readily available folder. if you are on Windows, make sure that you can see the Windows.bat file in there.
4) Download the 1.1.2 ipsw file and make sure it's readily available.
5)connect to iTunes and sync.
6) since you have installed OkToPrep, you are ready to update.
7) hold down your shift key (generally the left one) and then click on update(or restore -either might be displayed) and a window will open up to browse to the ipsw file you want to use. Locate the 1.1.2 ipsw and select it and then click ok.
8) Once the update has finished and it's restored your profile back on the iPhone, close iTunes and keep the phone connected.
9) locate and double-click the windows.bat file that came in the 1.1.2 jailbreak.zip file that you unziped. This will jailbreak your phone in 1.1.2. Follow any prompts it gives you, and then, once it has finished, re-install your sources and programs that you installed in 1.1.1
10) you are done.
mj2320
Jan 19, 2008
90
i would just go all the way to three
Bobby Digital
Jul 15, 2007
I heard three was kinda hard to play with and all the kinks werent out of jailbreaking that one yet... is this true. Would I follow the same instruction that hawk left?
6,682
49
Kind of...There is a tutorial on here that explains the process in detail.
I however have not been able to downgrade so I am stuck with 1.1.3 -jailed.
Bobby Digital
Jul 15, 2007
I haven't checked the tutorial yet but can I got from 1.1.1 to 1.1.3 jailbreak without messing with 1.1.2
6,682
49
It would be better if you did it in steps. I believe that you need 1.1.2 jailbroken with the latest installer to do it correctly.
Bobby Digital
Jul 15, 2007
Hawk why don't you have 1.1.3 jailbroken yet. Have you tried the steps illustrated in this thread?
Bobby Digital
Jul 15, 2007
it says to do a clean install of 1.1.3 so that means anybody using 1.1.3 through iTunes update can use this method to jailbreak right?
Bobby Digital
Jul 15, 2007
oh ok you scared me for a second there. I upgraded from 1.0.2 to 1.1.3 Jailbroken in about ten minutes. I know it was risky but I took the chance because my friend said he would sell me his for $100 if I bricked mine. but it worked out fine and I have had zero Problems. glad that you finally got to jailbreak again too. Happy Apping.
