Big problem - Audio Issue
mjeagent
Jun 28, 2007
418
Northern Virginia
Big problem - had phone hooked up to Belkin earphone adapter and then plugged into car auxillery to listen to Ipod. Worked fine and then unplugged and problems began. No audio in the earpiece (not earbuds); no speaker audible during Ipod and Youtube play. Speaker plays audio during call and for ring tones.
Did a reset and still no fix.
Any thoughts?
Silverado
Jul 6, 2007
332
Any thoughts?
Ouch... I hope there wasn't a static jolt that fried a circuit. What kind of a reset did you do?
ksyoh
Jul 13, 2007
Similar problem
Anybody?
I'm dyin here!
I had a similar problem. Resolution: I inserted the earbuds and it seemed to activate the earpiece when i removed it again. You probably already tried it but it's worth a shot.
My situation: i used the earbuds all night making a call. Today i tried making calls and the earpiece wouldn't work. No sound. The screen wouldn't shut off when covering the sensor while in a call either. It was like the phone didn't register that the headphone was removed. Speaker worked ok. In the car I used a Belkin ipod charger. Attempted a soft reset, then thoroughly pissed, I inserted the headphones when I got home and that seemed to do it.
I hope this wil do the trick.
askewed
Jun 22, 2007
147
NJ
Do a hard reboot (menu & sleep) with the headset plugged in. Let me know if it works.
mjeagent
Jun 28, 2007
418
Northern Virginia
Thanks guys...ended up having to jiggle the earbud plug until the sound finally came back on. Read somewhere that is possible to remove the headphone adapter or earbuds and a sensor inside the plug will remain open. Jiggling the earbud plug in and out will solve this issue.
Wish I would have figured this out before the Hard Reset.
aggieman
Jul 6, 2007
4,053
85
Dallas, TX
Thank goodness for this site. just had this problem...all fixed now!
Marjorie Searl
Dec 29, 2007
Sound problem fixed
:laugh2:
My thanks as well...my heart was breaking thinking that my iPhone was broken. It's become a body part at this point. I jiggled the earphone as well (had to do it a few times) and finally the sound came on.
