bighthouse outgoing mail problem (cwmx.com too) help please
cflamm
Jun 6, 2007
112
still having problems sending mail using edge on my brighthouse account. when on wi fi it's fine with the SMPT-server.cfl.rr.com, but on edge and switching outgoing to cwmx. com, i still have problems. sometimes it works, sometimes it doesn't.
anyone have brighthouse, (and central florida would be even better) that have been able to find a stable address on edge for outgoing mail using cwmx.com or other?
this has been going on for a month now. been reading that others are finding good stable solutions to their problems, but no one has mentioned brighthouse specifically that has found a stable mail out server.
have looked everywhere i can think of, including searches and other info here. still nothing that will work for my specific case.
suggestions/help would be greatly appreciated.
thanks
carl
ChArLiE713
Jul 3, 2007
149
I cant send nay email either on edge nor wifi(Road Runner) It is really bugging me out!
RLK
81
Indialantic, FL
From user vlj96 posted on 07-19-2007, 02:48 PM:
I set the smtp server to:
smtp-server.tampabay.rr.com:587
Username: your full rr email address like, username@tampabay.rr.com
Password: type it in
This worked for me in Central Florida on both Wi-Fi and Edge
Rick
cflamm
Jun 6, 2007
112
thanks rlk
finally a fix that worked!
now how about OUTSIDE florida? (cwmx.com still?)
papabro
Jul 23, 2007
101
MA
I have the same situation with my pop3 email account charter.net here in Massachusetts. I can receive using both edge and my home wi network but can not send using edge. I am thinking of going to yahoo mail.
jasunto
Jul 4, 2007
47
i happen to live in orlando and have brighthouse and previously worked for them as a service technician, now working for comcast in the same area doing internet tech support, check the FAQ's i know comcast has recommended port setting changes when off the comcast network whick using edge would be a good example of that
jasunto
Jul 4, 2007
47
for the first post, that is smtp not smpt, simple mail transfer protocol
jasunto
Jul 4, 2007
47
You can check your e-mail from another ISP by using one of two options. The first option is to setup an additional account in your e-mail application using the following settings:
Off-network POP3 Server: pop-server.cfl.rr.com
Off-network SMTP Server: Check with your alternate ISP for their SMTP Server name
Note: If you retrieve your e-mail from a computer other than your own, it will be removed from the server and loaded on to the computer you are using. To keep the mail on the server so that you can retrieve it again from your home machine, select the Leave Mail on Server option within your particular e-mail client. However, keep in mind that messages "expire" or are deleted from the server after 60 days.
The second option to check your Road Runner e-mail from another ISP is with Road Runner Web Mail. To learn how to use this service, select the Road Runner Web Mail - Using FAQ from the drop-down menu above.
