.bin to mpeg4 conversion
In2Deep
Jul 4, 2007
37
So whats the best way to convert a downloaded movie (.bin format) into an mpeg4 to view on the iPhone?
I have Sorenson Squeeze 4.2 but it doesn't work with .bin files.
alb0zf1n3st
Jul 2, 2007
624
Download a free program called VCDGear it will take the files out of .bin to mpeg format.. then use these other programs to convert to iPhone format
IPhone_Chica
Jun 14, 2007
77
Download a program called Direct Show Dump, it's free. I used to use it to transfer my .tivo files. Works perfectly. Then you shoot the resulting file through Videora or Super Converter to convert it to the proper iPhone format.
alb0zf1n3st
Jul 2, 2007
624
it is for CDS but you can remove the video from it usually when you DL files from irc or torrent they are .bin if you want the better quality VCD or SVCD
wjp09
Feb 25, 2007
2,559
25
NJ
Well if your taking the DL approach why don't you just dl it with the extension you want?
alb0zf1n3st
Jul 2, 2007
624
I don't know why someone would take that approach don't ask me lol.. I the way I see it .. It would be a headache to download a VCD or SVCD because they usually are 2-3 CDS you need to extract the videos then join the videos then convert them again all takes a sh*t load hours...
Although some releases are made VCD or SVCD first like a TELESYNC
Standog
Jun 26, 2007
97
A .bin file is a compressed file, like a .zip file. You need only to uncompress the file and then you can convert it. It is probably in an .avi or an .mpg format which you will see after opening the compressed file. WinZip should be able to open the .bin file for you.
In2Deep
Jul 4, 2007
37
VCDGear worked perfectly, and in less than a minute too.
Optimus prime and Megan Fox... yes!
alb0zf1n3st
Jul 2, 2007
624
You can use isobuster but #1 its not freeware to a certain point you need to register it i knew he wouldn't or knows how to make a keygen lol.. plus it will give you errors once a while for different files..
spyrwebs
Jul 3, 2007
90
Travelin man, SOCAL
.bin or .cue is a backup image of a CD. All you have have to do is burn the bin image into a CD or DVD using Nero or similar program. The only thing you have to make sure its burned as an image iso format for auto extraction. Then it can be converted into MP4.
