BiteSMS buggy on 6.0?
hmfc-1874
Sep 10, 2011
510
34
Hey, anyone using Bitesms on 6.0, having it with bugs? it wont notify me on new texts, quick reply wont come up then when i do check, it crashes the first time i open it when a new text comes in then i the app works second time trying ?
any help ?
cheers
5,578
Works fine for me. Are you using the paid version?
5,578
Okay. Just uninstall and reinstall it then.
hmfc-1874
Sep 10, 2011
510
34
cool will report back.
hmfc-1874
Sep 10, 2011
510
34
Seems to of works.
Thanks Europa, can always count on you !
Sent using iCafe app
hmfc-1874
Sep 10, 2011
510
34
The problem is back started again last night.
I downloaded a theme from cydia a few weeks ago for it, works fine the theme it's self but could this cause the problem?
Should I try and uninstall instead of change theme because changing theme it still crashes ?
