Blade by T.D Design Case Giving Bad Signal (help)
Rumdada
Sep 23, 2007
25
I recently bought an iPhone 4s and i had a Blade by case put on my phone. When using my phone out doors I would generally have a decent signal but indoors i would drop down to one bar and sometimes no service at all. So i decided to remove the case now I am getting 3-4 bars indoors when id usually only have 1 or sometimes no service. I have 2 questions 1 is there any way I could modify the case or do something to help my service with the case on ? also do other cases do the same thing to your iPhones? Thanks in advanced !
Mi-Phone
Feb 4, 2012
80
Reason your loosing signal is because the case is made out of aluminum and blocking the antenna from receiving good reception. Only way to fix is to cut around the area where the antenna is. Check out the element vapor pro case and you will see on those cases they use plastic where the antenna is so you still get good signal. Hope this helps in someway
