Blank Home Screen?
ADDam
Mar 2, 2008
439
Ann Arbor, MI
Ok, I have been Searching and reading for the last 2 days on my new iPhone. It is JailBroke, and running 1.1.4.
I really would like to find out how to have a blank screen on the Springboard, To show the full wallpaper. Any help is appreciated. I know I could just use one Icon and move everything else to another board...but thats not good enough.
pab277
Aug 1, 2007
25
why would you want a blank springboard? it wouldn't be possible to access the apps.
the only app i know of that hides springboard icons is 'poof' in installer.
but from what i've read, its not compatible with 1.1.3, let alone 1.1.4
ADDam
Mar 2, 2008
439
Ann Arbor, MI
Not 100% Blank, Just one Page, and then all the apps would be in the next one over, Just for a clean look. On my MacBook The only icon thats on my Desktop is MacHD...I HATE ICONS!
chrissurra
Jul 19, 2007
148
Thats what mine looks like I have the center page empty, main icons to the left and other programs to the right.
I used this program on my middle page to hold the spot
x999x
Aug 6, 2007
1,656
Howdy, the link above works well if you don't mind manually installing the file. Thats me on my alternate posting account btw ;) I love that monkey!
Anyway, I've since added it to my Installer Repository. Add this to your Installer Sources and look for Blank.app.
http://dezign999.com/repo
Enjoy!
Hondamaker
May 14, 2007
9,946
671
57
Fairborn, Ohio
I use it too, and I love having the first screen a blank one. x999x is the man!
x999x
Aug 6, 2007
1,656
Wow, suddenly I feel like unwrapping candy. lol
Hey HondaMaker, I think this Dock skin might compliment your dock icons. Its a black transparent fade so your icons get a little more pop without much of a strong presense.
If you'd like to try it, download the image above and name it Dock.png. Upload it to your SummerBoard theme that you're using and rename the existing Dock.png in that folder incase you don't like how this one looks.
You can find your themes folders here:
/var/mobile/Library/SummerBoard/Themes/
Drop that Dock.png into one of the folders within that Themes folder.
michael180
Jun 14, 2007
1,249
Santa Cruz, CA
moderntimes.com
Where can I get the icons for the dock? Also, when you unlock the phone which screen appears? I mean if the the above is the middle screen.
chrissurra
Jul 19, 2007
148
Here are all the icons zipped up
Removed.
If you have the blank app then when you slide to open it will open to whatever page you closed on.
If you left it on the blank page it will open to the blank page, if you close it on the icon page then it opens to the icon page.
Nov 4, 2008
ok, first off is this required to show the wallpaper on your backround?
And second off, I've never benn able to work 2.x installer so is/can it on cydia?
