Blank text fields
brevigMAN
Feb 7, 2014
Some apps on ios 7 that you have to type somthing into come up blank just wondering if there is a fix.
Sent from my iPhone using iCafe Forums
28,365
5,506
Some apps on ios 7 that you have to type somthing into come up blank just wondering if there is a fix. View attachment 35476
I haven't ever had that happen. Try a hard reset. If that doesn't work, delete and reinstall the app. If it continues after that, notify the app developer of the bug.
Docd
Oct 16, 2011
651
66
I noticed similar things like this when filling out a form in Safari on a couple different sites.
Sent from my iPhone using My fingers.
28,365
5,506
In that case, it might just be a general iOS 7 bug. Maybe there will be a fix in 7.1.
