Block a caller
Nov 10, 2011
I thought I read somewhere that with ios7 you could block a caller. Is this correct and how do I do it?
Sent using iCafe app
PinkBanana
Feb 16, 2010
1,476
94
Burnley, UK
There is a post on the home page that tells you how to do this. Under the main iOS 7 feature.
Bennyboy
Jul 21, 2010
14,017
1,756
PA
Under each contact, scroll down
5,578
Yes, that's correct. Add the number to your contact list if it isn't already there. Then select the contact and scroll to the bottom of their contact info. You will see an option for blocking.
Docd
Oct 16, 2011
651
66
You do not need to add them as a contact just go into your recent call list, tap the i to the far right of the number you want to block, scroll down and tap block this caller.
Nov 10, 2011
Thanks, worked both ways!
ozico80
Sep 19, 2013
Perfect !
flightmedic
Jun 21, 2009
397
23
Wichita Falls, Texas
Does it send it directly to voice mail? I also wonder if there is a way to access blocked messages like on some other apps.
Now that this is available stock, I may update to stock iOS 7 today...
rjkgr
Aug 14, 2013
183
thats so cool.. im going to block people i don't like haha
radtechy
Jul 20, 2011
505
41
You do not need to add them as a contact just go into your recent call list, tap the I to the far right of the number you want to block, scroll down and tap block this caller.
Thanks about the call list way
That's great going forward for me.
I made a contact called ZZ block list so its on the bottom of my contacts and it has 5 numbers in it and I blocked that but if I need to do more I'll use the recent list
Sent from my iPhone 5 using Tapatalk
