Block numbers?
Sep 6, 2010
2,485
22
Are you referring to accidental dialing here? If so, lock your iPhone....
Sent from my iPhone 4 using iCafe app
catt09
Jun 6, 2011
Can you somehow block numbers from calling your iPhone, from your iPhone?
Although it's not technically "blocking" #'s, the free and easy way to do it is just give the unwanted # a ringtone on which you set the volume to zero. At least you won't be interrupted, and maybe they will give up.
