Blue Screen appears when trying to identify the IPHone
Nov 27, 2007
Hi,
Yday I got an iPhone and I was able to copy some mp3s using iTunes. But since today when ever I try to connect the iPhone comes the blue screen.Its says detecting Camera...and displays the blue screen. What shall I do about this problem. I have windows XP and the latest iTunes version?
Cheers
6,682
49
silly question, but have you tried restarting your PC?
termleech
Sep 7, 2007
1,154
McPherson, KS
Disable autoplay in Windows. What is happening is Windows detects your phone as a camera. You do have iTunes installed, correct?
Chris716
Nov 29, 2007
807
IL
yes disable autoplay next time the message comes up i was having the same issue where it would come out now problem solved
Doby45
Aug 21, 2007
543
Powder Springs, GA
Yhea, just disable autoplay in Windows. Windows is detecting your phone as a camera. Do you have iTunes installed?
Just figured I would jump on the "lets echo everyones comments" train.
Nov 27, 2007
Yes I do have iTunes. But win xp doesn't recognize iPhone.Fining a way to remove iTunes completely n reinstall because missing Apple iPhone usb driver ...
Regards
BillSinAtl
Jun 12, 2007
Atlanta
If you had a Mac, you wouldn't be having this problem. Couldn't resist!
:p
