Blueprint 3D
Napoleon PhoneApart
Jun 19, 2007
33,493
4,417
Upper Marlboro, MD
I recently purchased this amazing game that makes you think in three dimensions and tests your spatial skills. You start with a scattered mess of dots, dashes and shapes on a blueprint. By rotating these images in three dimensions, you gradually make sense of the chaos and discover the image before you.
http://itunes.apple.com/us/app/blueprint-3d/id456244246?mt=8
There are over 240 levels. You can even purchase solutions packs if you get really stumped. This is really worth checking out!
  • Like
Reactions: JWiPhone
Bennyboy
Jul 21, 2010
14,017
1,731
PA
How you get the download link now from the app?
I have the game btw, it's awesome.
iphonewarrior
13,847
699
You can do this loads of ways i.e through the online website or through the App Store app. For example, if you use the App Store app, launch the app and find the app you wish to download. Once you've found the app, you get the option to share a link to the app. Tap on share and your device will automatically open up the Mobile Mail.app with a pre-composed email. You will see a direct link to the app, copy and paste away :)
Bennyboy
Jul 21, 2010
14,017
1,731
PA
since 5.0 it only gives you a button option "view item" which it takes you back to the app store. I even tried to email my self the app and still I only get the view item button, no link.
iphonewarrior
13,847
699
Do you not get the menu which says, 'Tell a Friend.'
e.g
iphonewarrior
13,847
699
yup, and now you get this
Right, they've changed how that used to look lol. Another (stupid silly way) option is to email that pre-composed email to yourself and copy and paste the link lol.
Or you could just go to Apple's online website and copy the link there... :)
Bennyboy
Jul 21, 2010
14,017
1,731
PA
Ok, thanks guys, haven't been able to figure it out (or I just gave up on it) since 5.0
