Bluetooth connection iPad 2 and iPhone 4
jbenmore
Mar 25, 2011
Hi. I just bought iPad 2 today wifi only. My iPhone is jail broken and I'm sure I've read somewhere that you can connect the two so that the 3G of the iPhone can be used on the iPad. I've tried connecting them via Bluetooth but says not supported. Any advice? Thank!
Mar 24, 2009
1,005
Atlanta, GA
You only need MyWi on the iPhone to use it's 3G on your iPad..
I believe that's what you're trying to do, right? Get on the internet on your iPad, using your iPhones 3G?
it's called 'tethering'
Mar 24, 2009
1,005
Atlanta, GA
MyWi is in Cydia.. it's $19.99 (a one time fee) and it's worth EVERY penny...
from there, y ou set up a network (like you would a home wifi network).. it's fairly simple..
once you get your iPhone network set up, use your iPads wifi (Settings/Wifi) to get on to your iPhones Network...
once on, you should be able to surf the web freely on your iPad...
Michael Baturin
Jul 11, 2007
1,745
238
31
South Jersey
There is a new upgrade ($5) in MiWi called OnDemand which allows intelligent Bluetooth connecting of iPad to iPhone. Without ever needing to open the MiWi app, iPad will connect to iPhone via Bluetooth (much less battery) whenever the iPad is unable to connect to a free wifi hotspot. thus allows you to have an "always online" iPad without sacrificing battery.
WARNING: there is one caviot I did not see before I purchased....both the iPad and the iPhone have to be jailbroken! Since iPad 2 cnnot be jail broken yet, I would reccomemd holding off on that feature until it is able to be jailbroken.
kiwee
Jun 17, 2010
136
Toronto, ON
just an fyi, i was contemplating getting mywi for the last few days since i got my ipad 2, but after reading this post, i just went and got it. thanks guys.
Lon
Jun 5, 2010
2,946
132
Alaska
Remember you have to jailbreak ipad2 and currently you cannot to tether via Bluetooth
Just to clarify. To use MyWi, your iPhone has to be jailbroken; you're iPad does not. Once activated on your iPhone MyWi will show up in your iPad WiFi Settings just like any other WiFi access point.
Tinman
4,334
183
Aridzona
To clarify further :) you can also tether via Bluetooth. This is a (crude!) video I shot with my iPhone to show how a WiFi only iPad 2 "appears" to be using the iPhone 4's GPS when in fact it is actually using WiFi for location services.
Michael
Michael Baturin
Jul 11, 2007
1,745
238
31
South Jersey
Not true! I tethered my virgin iPad 2 to my iPhone 4 via Bluetooth and it worked just fine. You can do it via MyWi or via official AT&T tethering.
Michael
Woh Woh Woh. Tethering Bluetooth from iPad 2 to iPhone 4 from what I have read on MyWi's website is not available unless the iPad is running MyWi as well. I have tried to connect my jailbroken iPhone 4 to my virgin iPad 2 via bluetooth and it never works.
I am specifically looking to use the onDemand feature which clearly shows the need for both iPhone 4 and iPad 2 to be jailbroken here:
How are you creating a stable and fast tethering connection between these via bluetooth without iPad being jailbroken?
Lon
Jun 5, 2010
2,946
132
Alaska
What would the advantage be to Bluetooth v. WiFi?
Tried that same thing last week on road trip from CA to WA. Acceptable for amusement but nothing I would rely on.
Michael Baturin
Jul 11, 2007
1,745
238
31
South Jersey
A stable tether via Bluetooth uses much less battery and is thus an advantage. Additionally MyWi has created an OnDemand feature which as I stated in an earlier post, will automatically determine when you are not connected to a regular Wifi network, and intelligently tether via bluetooth for you. Using this technology, your iPad will always be online everywhere you go (as long as you have your iPhone with you).
