Bluetooth won't work (HELP)
kcarr91
Apr 14, 2007
62
when i got to activate bluetooth it turns on but it says under devices searching and it will not stop searching
any ideas / suggestions on how to fix it
i have never modded or hacked iPhone
had it since jun 29 but never turned on bluetooth (until now)
tried restarting phone soft and hard
thanks
Iceblinkluck
Mar 30, 2007
129
Long Island NY
thanks
Have you tried pairing it with anything? Like a headset or a computer to see if it will pair? Once you turn it on, i think it stays discoverable.
kcarr91
Apr 14, 2007
62
i tried that just now with my old razor and it says
unable to connect and then service not supported
but it did find the iPhone
Iceblinkluck
Mar 30, 2007
129
Long Island NY
try it with a headset, that is the only thing that the iPhone bluetooth is currently useful for with the iPhone. There is no file sharing via bluetooth at this time.
kcarr91
Apr 14, 2007
62
i was trying to pair it with a headset but i cannot
it says searching and i cannot get it to stop so it not possible for me to pair it
Iceblinkluck
Mar 30, 2007
129
Long Island NY
just to be sure, does that same headset pair with your razr? This will verify that the headset is not currently malfunctioning. If the headset pairs with the razr but not your phone, then I would try calling Apple or making an appt at a local Apple store.
kcarr91
Apr 14, 2007
62
ok i will makke an appontoment at the Apple store b/c this does pair with my razor
thanks
