Bootneuter icon appearing on homescreen after using WinPwn
amiroo79
Nov 3, 2007
217
Southern California
Does anyone know why the bootneuter icon stays on your homescreen after unlocking/jailbreaking using WinPwn? I understand it was necessary during the bootneuter process but does it have to stay on my homescreen? And if it does, can someone accidentally launch it and run it and harm my phone?
This reminds me of the old 60s spy movies where there would be a SELF DESTRUCT button in some villains lair...
forkee
Sep 6, 2007
348
most likely because you didn't check the box "autodelete bootneuter app"
just use "poof" application to hide it
blacksheep5
Dec 15, 2007
Iraq
Mine is on the screen too, but I don't remember seeing a "autodelete bootneuter app" anywhere while I was using Winpwn.
But I did the same just used "Poof" in BossPref
blurm
Sep 9, 2007
46
Bootneuter
If my understanding is correct Bootneuter is an application which explains why is shows up on the screen. If you want to remove it simply open the installer and choose the uninstall tab and simply remove it unless you anticipate returning to the 4.6 in the near future. If you need you can always reinstall it later.
