bricked iPad?
molotovtaco
Sep 6, 2011
Hey guys, I installed jailbroken iOS 5 beta 7 using sn0wbreeze and booted with iBooty. I went into Cydia and installed a couple things and then tapped 'Reboot Device' thinking that it would just boot and none of the jailbreak apps would be there. I'm stuck in a recovery loop and no matter what combination I do with the home and power button it won't go into DFU mode. It will not connect to the computer when I have the usb cable plugged in. Did I brick it?
iNinja
Aug 8, 2008
3,986
20
UK
Highly unlikely. Does iTunes recognize it at all? Do you get a pop up saying any device is in recovery mode? If not, hold down the home button when you plug the device in and you should see a warning that the device needs restoring.
Can you switch it off?
