Broken iPhone charger! What to do?
paintdude258
Jul 5, 2007
50
Well so turns out the little white box that came with the iPhone to plug it into the wall is broken. the cord still works but for some reason the white box wont charge my phone? should i contact Apple? just buy a new one? or what?
RJ1
Jul 8, 2007
81
Celebration FL
did it drop? how is it broken? I guess youll have to plug it in the computer unless you want to spend $30 for a new wall charger
Maaz
Jun 30, 2007
584
LA California
yes common issuie just go to your Apple store and ask them to exchange it with a new one.
Maaz
Jun 30, 2007
584
LA California
yes common issue just go to your Apple store and ask them to exchange it with a new one.
paintdude258
Jul 5, 2007
50
Could I return it to a Cingular store? And no I didn't drop it! It just stopped working!
Jul 23, 2007
Hey,
I had the same problem where the power brick would not charge. I took it in to the Apple store and asked them to check it out. The guy went to the back for a few minutes and came back out with a new power brick. He just handed it to me and said "Here." Kind of rude on his part, but at least I got it replaced.
Just take it in.
Sep 20, 2009
Same Problem
i got the same problem but my chord doesn't charge anything.....it only syncs ...should i take it in? i probably wont get another on back tho.....:mad:
5,580
If your USB cord is defective, and the phone is still under warranty, Apple will replace it for free. If it's not under warranty, I strongly recommend avoiding aftermarket cables, and instead getting a genuine Apple iPhone USB cable. Errors can occur while updating the FW or restoring the phone when using aftermarket cables, especially with the iPhone 3GS since it draws more juice.
The warranty is good for one year from the date of purchase or 2 years from the date of purchase if you got Apple Care. If you bought the phone used, it will be good for one year from the sellers date of purchase.
You can find one at BestBuy or an Apple Store or just buy one online.
http://store.apple.com/us/browse/home/shop_iphone/iphone_accessories?mco=NzcwNjgyNA
