Buying an old iPhone
xbm123
Jun 19, 2008
How hard is to buy/find the current iPhone? Also, what are the cons to buying an "unlocked" iPhone, and would i still be able to hook up the "unlocked" iPhone to an ATT family plan?
Saverino
Jun 1, 2008
4,480
92
Burbank
Its not really that hard. Just search on eBay or craigslist or something.
And unlocked just means you can use it with a different carrier.
And yes you can hook up an unlocked one to an AT&T family plan.
xbm123
Jun 19, 2008
would i still be able to get the updates from Apple and what not?
Saverino
Jun 1, 2008
4,480
92
Burbank
No. Once you get it, and if it is unlocked, you can restore it through iTunes, and then it will be able to get updates and stuff, but it will only work with AT&T, which doesn't seem to be a problem since you asked if you can add it to an AT&T plan.
xbm123
Jun 19, 2008
Just for future reference, is the restoration process easy?
V1 iPhones are still available from Apple and AT&T until July 11th.
- john
Ace4261991
Jun 18, 2007
530
- john
if your gonna use AT & T don't buy it unlocked because your gonna end up paying more for an unlocked one then one thats not so theres no point.
dturner
Dec 15, 2007
5,725
Louisville, Ky.
You can restore a phone through iTunes. I would go ahead and do this if you are going with ATT anyway. This way you can have the firmware update coming up soon and the app store.
xbm123
Jun 19, 2008
I am just trying to figure out what would be the better choice. 35 dollars a month is pretty steep. I live and go to school in major cities so coverage and getting Wi-Fi isn't difficult. I could care less about GPS, but i'm not sure if an extra 160 over 2 years is worth it for faster internet. What are your guys suggestions?
