Calendar alerts/alarms
lumax
Aug 31, 2009
Hi,
I am new to the iPhone (3-g) and I have to say that the calendar function could be better. On my old phone I would get a loud alarm at the time of an event and the alarm would sound for 1 minute. With the iPhone you get 2 short chirps that can be drowned out by a pin drop. I have done some research on this topic and it appears that Apple might be working on this issue by either improving the alerts or by allowing application creators to the operating codes so that the apps. can also have better alarms.
Does anyone know when Apple might be improving on the calendar alarms or releasing the codes for app creators?
Are there any apps that have better calendar alarms? I have Pocket Informant.
thanks
Terry M.
Feb 27, 2009
728
84
46
Des Moines, Iowa
Did you try some different alarm sounds? I've got a calendar alarm that is stock and makes people turn their head when it goes off. I'll post back in a minute with which one it is.
lionqueen
Aug 28, 2009
295
Beautiful San Francisco
I'm not really thrilled with the Calendar either. On my old phone I could set as many alerts as I wanted, and could set it for any day or time, like tuesday at 3:31 pm, five weeks from now. It's one of the few things I miss about my old phone (that and being able to use custom tones for my SMS tones, instead of pick one of five or so that Apple things I should use).
There's a few things I dislike about the iPhone, definitely. Luckily, the good stuff about it does make up for the bad. I do hope they improve the Calendar app though - honestly I find it a bit half-assed.
eye-Fone
Jul 5, 2008
1,024
14
Sunny, southern California.
I don't like the fact that I cannot snooze a calendar appointment reminder. That really blows. Windows Mobile has this--does Android or the Pre have this feature?
I know I can set two alerts for one appointment, but that's not the same as snoozing.
MrMike6by9
Nov 16, 2008
1,482
119
71
Maryland, USA
I've found that I prefer the options I have Google calendar and miss the auto profile switching I had with my Q9h, i.e. the phone would switch to vibrate for appointments tagged as "busy".
lumax
Aug 31, 2009
Terry,
The only calendar alert I could find is under "sounds", "calendar alerts", and the only option there is ON or OFF.
styfle
Mar 31, 2008
3,381
I want a snooze for calendar alerts. I really like the calendar but there is much to be desired as stated above.
rick and stuff
Sep 4, 2009
NH
In addition to the above, I hate that the iPhone calendar only gives you pre-determined alert time options (i.e. 5 min, 15 min, 30 min, 1 hr, 2 hr, 1 day, 2 days)... no custom alert times.
garykirsten63
Jun 30, 2009
231
Terry,
Such a nice tip. I was facing from same problem. Now I have fixed it using the procedure you said. so much thank you for sharing.
ERA818
Sep 8, 2009
NJ
Can I set a default alert time? (I am a Blackberry defector, there you can set an alert for 15 minutes, or anything else you want. (1) The iPhone has a set menu of choices; but (2) more importantly I want to set the default alert so that I don't forget to do it before I save the appointment!
I am a newcomer, please excuse me if this duplicates a previous discussion. I could lnot find it by searching. I must say the iPhone is a treat comparedc to my discarded Blackberry.
MrMike6by9
Nov 16, 2008
1,482
119
71
Maryland, USA
You can set various alert/reminder times in Google calendar which I use; any number of minutes up to 4 weeks. These can be emails, on screens messages, or come to your phone as a SMS text but sadly no snooze there either. Oh well.
YMMV
CAl Al
Aug 27, 2010
a long and loud Calendar Alarm
We made a loud and long alarm possible with an app called Calendar Alarm, now available in the app store. The alarm syncs with the standard Calendar. There are 12 sounds to choose between and the sounds rings for 10 or 30 seconds. In the upcoming version next week a repeat/sleep is added that will go off every minute till you stop it. App store link http://itunes.apple.com/app/calendar-alarm/id367803799
Tinman
4,334
183
Aridzona
YMMV
I use Google Calendar as well and have it synced to my iPhone. At least the SMS is louder and a secondary reminder. Plus if you ignore the text or miss it it will sound again for you whereas the default calendar alert will not.
Michael
