Calendar Appointment Time Quirk
DRabbit
Jul 2, 2007
383
Yes, I have my timezone set up.
I can't nail down exactly when this bug crops up, but I figure SOMEONE else has to be experiencing it.
I have some appointments set up. Not recurring... just stand-alone appointments. Every once in a while, when I go back to check them, the time on them has changed... to four hours earlier! But it doesn't appear to do it to ALL my appointments. I can't figure out when it's happening as I've check after syncing and that doesn't appear to be the cause (though I can't be 100% sure since I don't check every time I sync).
Anyone experience this and know the cause?
kimkim
Aug 15, 2007
The Fix
I had the same problem. It is most likely your time zone settings.
On the home screen on your phone go to Settings-> General-> Date & Time.
Turn Time Zone Support ON. Then enter your time zone in the box below. You are prompted with a text box when you touch on the time zone line. As soon as I typed in Washington, DC and reopened my calendar it was fixed.
Good luck.
