Calendar events and changing time zones.
Docd
Oct 16, 2011
651
62
Taking a trip and set my plane reservations up in calendar. Now by default all the times are already set to local time of the departure/arrival city. But when I change time zones (in this case 3 hours) it adjust the times on the calendar automatically.
Anyway to fix this.
Docd
Oct 16, 2011
651
62
Thanks. That's only half I was looking for. When I do that it screws up the time the other way. I was looking for a way to lock in to the time I set on a case by case event. As an example is I set my flights an I cross time zones it shifts all of my flight times by 3 hours. Wish I could lock each by the local time.
iPutz
Nov 20, 2012
964
183
43
74
US Midwest
From what I understand you will need to set the calendar so that times don't get changed when changing time zones then reset all the incorrect times manually but that sounds too much like work. With luck someone else will have the correct answer and we can both learn something.
