Calendar item alert glitch
iPutz
Nov 20, 2012
962
184
43
71
US Midwest
I was curious if anyone else has noticed this. Before iOS9, when I would enter a new calendar event, I would give it a name, start date and time. I could also set two alerts to that event for a time prior to the event. The initial "Alert" was set at one of 9 preset times and the "Second Alert" was set, from the same list of preset times, but for a time somewhat closer to the calendar event. Under iOS9 if I try using that method, the entry for "Second Alert" causes the initial "Alert" entry to be changed to match that of the "Second Alert". Under iOS9 it seems that the "Second Alert" entry must be for a time prior to the initial alert time rather than after it as had been true before. The same is also true of my iPad as well. This is happening with an un-jailbroken iPad 3 and an un-jailbroken iPhone 6.
Ledsteplin
Oct 29, 2013
4,831
988
65
Florence, AL
That's how it's been all along for me. My first alert would be 2 hours prior to the event. My second alert would be the day before. It's been that way as long as I can recall.
iPutz
Nov 20, 2012
962
184
43
71
US Midwest
That would happen occasionally to me as well but entering one alert would never change the value of the other until now, it may have shifted it to the other position but not change it. Oh well, I will just need to get used to entering the second alert first and then the other one after. Weird?!?!
28,365
5,507
I just tested it on 8.4 and the first sometimes changed after a second alert was added. It wasn't consistent.
I always add two alerts, but I usually add the second alert first (for sooner date), so I never noticed it.
iPutz
Nov 20, 2012
962
184
43
71
US Midwest
I would expect it to at least be consistent in the way it acts. Oh well, at least I know I'm not the only one who is having this issues with this, Thanks Y'all.
iPutz
Nov 20, 2012
962
184
43
71
US Midwest
OK, it is time to start scratching my head. This morning I entered a calendar appointment and everything was working as it used to with the alerts. I tried two more fake ones and it all works the way it used to. Is that Rod Serling's voice I hear saying something about having crossed over into the "Twilight Zone"???
MrMike6by9
Nov 16, 2008
1,482
120
70
Maryland, USA
9.0.1 is out. One of the issues it addresses relates to alarms and timers.
YMMV
