Calendar Snooze
Francois
Nov 18, 2012
34
When I select snooze on a calendar reminder, is there perhaps a setting somewhere to specify after how long it should remind me again?
Sent using iCafe app
RoofMonkey
Jun 21, 2010
8,894
2,058
Not that I know of. It's 9 minutes & that's it.
Francois
Nov 18, 2012
34
That's the problem, I tap snooze but it never sounds another alarm, not even after 9 minutes. The normal alarm (clock function) keeps on sounding every 9 minutes but not anything from the calendar.
6,682
49
The alarm clock has snooze. The (stock) calendar has alerts. You can have one or 2 alerts set, but once it has sounded, it doesn't sound again. Each alert is a one time only alert.
The (stock) alarm clock will snooze for 9 minutes.
Francois
Nov 18, 2012
34
Thanks. The button for the calendar still says "snooze" so that's rather misleading I would say.
6,682
49
Are you using the stock app? Mine just gives me a notice which I can click dismiss
Francois
Nov 18, 2012
34
No app, just the default calendar with a sync to Microsoft Exchange Mail/Calendar
Ledsteplin
Oct 29, 2013
4,849
1,002
66
Florence, AL
Can you show a screen shot of where it says Snooze on the calendar?
Francois
Nov 18, 2012
34
See screen attached.
5,578
After you press snooze, it will only sound again if the display is off.
