Calendar times not right
smknSRT8
Oct 13, 2007
1,325
I just noticed when i looked at my calendar today that most of the times were an hour earlier. i say most because i am not 100% sure of the time and would have to double check them. the reason this happened i think is because i went into GENERAL SETTINGS then DATE AND TIME then in calendar i changed it to 'INDIANAPOLIS' . but the thing i don't understand is that ever since i have had the phone i have been in that time zone. any ideas on how i can change this or just simply add an hour to all my calendar events. i have a macbook pro and i use iCal if that helps. thanks in advance
seb481
Aug 3, 2007
774
San Diego
In settings>general>date&time, is your calendar "time zone support" ON or OFF? If it's on, try turning it off. If it's off, try turning it on. It should work
smknSRT8
Oct 13, 2007
1,325
i just changed it from ON to OFF. one thing that i noticed. all the calendar events that created on my phone are an hour earlier. and the calendar events i created on my computer are the same.
plasmo
Jul 8, 2007
123
this problem happens to me twice a year. I end up manually changing the upcoming incorrect times unfortunately. i wish there was an easier fix for this. I tried downloading the DST patch from MS outlook site, and also tried turning DST off/on as posted above, but it makes other appointments screwed up as well... (eg. all-day events span 2 days, etc).
The same thing happened to me last week. Turning it on and off worked.
GolfNut
Oct 15, 2007
Thanks everyone for this thread. Turning the mode on and off fixed it for me as well. This should be added to the Newbie FAQ sticky.
thegasguru
Jun 27, 2007
180
FWIW: turning it on/off worked for me too. Actually, I discovered that the "time support" option had somehow been turned off, and when I turned it back on, all my one-hour-off appointments magically self corrected (btw, this occurred around the time of the Daylight Savings Time change). But I drove myself nuts downloading Outlook patches and XP fixes, etc. before I finally discovered teh problem.
ColsTiger
Mar 8, 2007
5,856
Columbus, GA
I've never had this problem. When I initially got the phone, I set the Time Zone and DST and I've never had any issues since.
