Call forwarding only when there is no service?
wildonrio
Jul 4, 2007
2,002
Provo, UT
I don't have call forwarding enabled, since it would be on 100 percent of the time. It would be useful if call forwarding worked when my iPhone was out of service or range. Is this an option?
SmartAlx
Jun 7, 2007
1,087
If this were possible, it would obviously have to be something you would set up with AT&T, wouldn't it? How would the iPhone communicate to AT&T that you want call forwarding if there's no service. The only way it would work is if AT&T sent out a call signal, received no answer back from your iPhone, then came to the conclusion that your phone is in a no service area, or that the phone is off. Would you want call forwarding if you turn your phone off?
Anyway, give AT&T a call. You would be surprised at the cool services you can get if you just ask.
