Calling all HVAC experts
psylichon
Oct 31, 2007
16,591
751
42
Philly
I'm trying to install a Nest Learning Thermostat alongside a Crown AWR-series natural gas boiler. The Nest doesn't charge properly with my 2-wire R/W thermostat line due to power-stealing from the controller, so I'm trying to add a third conductor (C). I've run the line, but I can not figure out where on the controller to connect it... mine doesn't have a dedicated C terminal. It should tie to common ground, but that doesn't seem to work.
My thread on the Nest forums:
https://community.nest.com/message/1705#1705
Honeywell S9361A controller manual: https://docs.google.com/gview?url=http://dl.owneriq.net/a/ad76b75a-c0f3-4a06-b130-ecea5f97dab3.pdf
Perhaps a long shot, but maybe someone here can clue me in on what I'm missing.
Other than the fact that I have to keep pulling the unit off and charging via USB, I love the Nest. Very slick unit. I just can't fully utilize it until it's charging on the wall.
RoofMonkey
Jun 21, 2010
8,926
1,983
Run an extension cord? Haha, joking of course. Good friend of mine runs an AC businesss and they install the nest systems. Being in Florida, they don't run into boiler situations often, if at all, but I will certainly pick his brain for you.
Keep us updated & ill see if he has any thoughts on this.
Sent using iCafe app
Rugaby
Feb 18, 2011
7,122
1,172
Washington state
Is your common ground a for real common ground or does it ground along with something else? Your new unit probably wants a dedicated three line system correct?
chris
Administrator
Administrator
Jun 10, 2006
11,817
1,707
Long Island, NY
Wish I knew how to help. Have the Nest, but had an electrician install it. All I can say is that it's awesome once you get it up and running.
