Camera broken.
Elizabeth93
Nov 6, 2011
I have an iPhone 4 if I'm correct, I'm having really bad camera issues; when I open the camera app the shutter appears to be closed and the phone reboots. Any ideas as to what it is, how to fix it, or what I should check? Could it be a virus?
RoofMonkey
Jun 21, 2010
8,921
1,983
You can try doing a hard reset first. Won't remove data or anything. It's just a complete shutdown of the device.
Press and hold both the home a s sleep button together. When you see the slide to power off slider, KEEP holding them. When you see the Apple logo, then release both. It will take a bit longer for the phone to come back to a usable state ( maybe a minute or two )
See if that helps before trying a restore.
Elizabeth93
Nov 6, 2011
I tried the hard reset and it didn't work, the camera/video button also flickers. But my next question is what happens if I restore it when it's jailbroken? And should a back up my apps and stuff?
Jdog22
Nov 14, 2011
You might have a defective camera...You can get it replaced, I went through a company called iRepairFast, they have great prices and fast turnaround.. Link Below
iRepairFast
Rugaby
Feb 18, 2011
7,122
1,172
Washington state
Very good advice.
It's 60 to 65 seconds from when you see the Apple logo. Btw
