Camera flash
dinosaur1
Nov 10, 2007
516
Last night our waiter tried to take a pic of me and my wife. The light was pretty low. When she took the pic the flash didn't come on making the pic look horrible. I had to manually turn the flash on in order for the pic to look good.
Is this a defect?
Sent using iCafe app
RoofMonkey
Jun 21, 2010
8,891
2,057
Is this a defect?
Was the flash turned off? Try a hard reboot of the device and see if that helps fix the issue.
Josh Yates
Jul 14, 2007
563
32
Orion, MI
I've found that the iPhone 5S tends to seem to "need" the flash less when on auto. Don't know that I agree with that "need", but it doesn't use it as often. :/
shutter13
Jan 8, 2009
2,206
149
We'll if the choice is "auto" or "on", then yeah, I can see it flashing less than every single time, while on auto. /sarcasm
I assume you mean to compare the "auto" between the 5s and the 5, it read different.
The choices are "on" "off" and "auto". My experience is that auto doesn't work well either.
Josh Yates
Jul 14, 2007
563
32
Orion, MI
Um...yeah. I suppose if your intent was to be snarky, then you would read it that way. The assumption would be to compare the 5S/5 auto flash.
dinosaur1
Nov 10, 2007
516
I'll just leave it "On". That's dumb though.
showguy
Dec 2, 2007
769
Long Island, NY
Same here. I find I have to use my judgment and force flash on. The auto setting does not work well.
