camera lens
kbhark
Jun 28, 2007
55
Does anyone know what can be used to clean the camera lens? My seems to have some marks on it. Thanks!
Griffinaz
Oct 5, 2007
1,046
Phoenix, Arizona
I read somewhere, maybe on here, that some people are using a real cotton tipped q-tip dipped in eyeglass cleaning solution. I haven't had the need to clean the lens but that is what I would use. Remember, even truly cotton q-tips are not ultra-soft and if you press too hard you can potentially scratch the lens or the cover over the lens.
dcom
Aug 7, 2007
1,421
Suwanee, GA
I use a microfiber cloth. Seems to work fine. I don't use the one that came with the phone, it only seems to smear the smudges. I got a big pack of yellow ones at a local Costco. They do a great job of cleaning the iPhone screen and also make my MacBook screen look new.
mrgrumble
Oct 26, 2007
117
Strong Island, NY
I use solutions for LCD cleaning solution the same that use with my tv and the microfiber cloth seems to be doing the job perfectly
fury
Oct 23, 2007
2,274
238
34
Louisville, KY
I use a 3m high performance cloth. I got it with an eyeglass cleaning kit. When even that thing needs cleaning, I throw it in a hot washer load and dry it in permanent press. Then it cleans like magic.
I clean the screen and camera with the cleaning cloth and a bit of alcohol.
