Can 2 Bluetooth headphones be used at the same time?
Oct 3, 2009
986
31
Looking to allow 2 people to watch movies in the truck. Will the ipad2 send audio to 2 Bluetooth headphone sets at the same time?
OR
Cand I use one bluetooth headphone set and a wired set at the same time?
Marianne
2,326
29
Massachusetts
marianneschultz.com
Unfortunately, I don't think using 2 pairs of Bluetooth headphones at the same time is possible - while an iPad can connect to more than 1 Bluetooth device at once, I believe this is restricted to one keyboard and one headphone/headset only.
I've used a headphone splitter to watch a movie with someone else on my iPad. I have this Belkin one that's only $4 on Amazon right now - works like a charm: http://www.amazon.com/Belkin-F8V234-GLD-APL-Speaker-Headphone-Splitter/dp/B000222YR8/
Oct 3, 2009
986
31
I would rather do it wireless. Tons of cords and crap all over the place and traveling with a puppy just makes for a headache.
Gotta be a solution that is wireless.
Tyger_purr
Oct 3, 2010
179
I don't know for sure if this would work but in theory you could get two Plantronics Backbeat 906s and a splitter.
the 906 has a bluetooth device with a headphone jack that you plug into audio devices that do not have internal bluetooth.
Tinman
4,334
183
Aridzona
I know I have had two BT headsets connected at the same time, but I think only get to use one. Not sure I can even use one for telephone and one for music. As suggested splitter would be needed and then if wireless two BT transmitters. Or maybe there is a non-BT wireless headset solution that uses just one transmitter for two headsets.
Or just use one wired headset and one wired... again with a splitter.
Michael
iP5
Sep 7, 2010
2,964
136
Toronto
Because I believe you have a second phone, that other one can have BT device assigned to media and another BT unit to telephone and both connected at the same time. As far as I know though, only one can actively be playing.
Sent from my mobilephone using Tapatalk
