Can anybody help me on ringtones?
imran1712
May 11, 2009
My iPhone is not syncing ring tones from my computer. Can anybody advise me how can I fix this problem?
28,365
5,507
Are the ringtones showing up in your iTunes library? Did you make the ringtones with a program such as iRinger or did you download them directly from iTunes. Check to make sure the box for each ringtone is checked.
Jul 19, 2008
3,585
40
London or Miami
Make sure they are no a milisecond longer than 40 seconds else they wont be synced to the phone.
Also makesure the ringtone is in MP4 format if you made the ringtone from garageband or iRinger. It should work fine if downloaded from iTunes.
