Can anyone help with app updates
big*W*
May 14, 2012
London, England
I've got an iPhone4 and for some reason it wants to update apps which are not on my phone but on my wife's. When asking for the password it shows my wife's user account!
Has this happened to others? Is their an easy resolution or an I looking at a phone reset?
big*W*
May 14, 2012
London, England
Thanks for the advice. I've done that on my phone but no change, it keeps finding the wife's account for some reason. I won't have access to iTunes on my computer until Friday, I'll have to give that a go an let you know.
owieh
Jul 15, 2010
481
60
Sheffield, UK
twitter.com
Are some of the applications on your device been bought using your wife's account? If so, this issue will always occur when those apps need updating. The App Store will need her login for those updates to be applied. Just double check the apps on your device. :)
big*W*
May 14, 2012
London, England
We do have some of the same apps but my wife has only ever purchased hers on her phone and it was months ago when she last connected to iTunes on the computer. I'll get on the computer on Friday and give the logging out of each account a go.
owieh
Jul 15, 2010
481
60
Sheffield, UK
twitter.com
The issue isn't really about who is logged in... It's with the applications on your phone that might have been bought using your wife's account.
When you sync your phone to iTunes where your wife syncs hers, apps will be saved to that computer if both of you authorised it to "play" stuff both of the accounts bought.
By synching your phone to that computer, some of the apps she bought might've been synchronised to your device, that's why when you try to update on your phone App Store asks for your wife's login.
