Can I add custom text alerts on iPhone?
xxsirvtecxx
Mar 3, 2008
65
Milwaukee, WI
Just wanted to know is there a way to add custom text alerts? I'm kinda getting tired of the whole 10 that I have that are stock in my phone lol.
aggieman
Jul 6, 2007
4,053
85
Dallas, TX
as far as I know we are stuck with the alerts that are there. I haven't jailbroken my phone though. there may be options for jailbreakers, that one I'm not sure about.
AntonChigurh
Jan 30, 2008
226
You have ten different text sounds on your phone? Mine only has three. I wish I had ten.
I have changed my text message sounds using WinSCP.
All you have to do is replace the default sound file.
/System/Library/Audio/UISounds/sms-received1.caf
/System/Library/Audio/UISounds/sms-received2.caf
/System/Library/Audio/UISounds/sms-received3.caf
etc.
Good luck!
cu0ngsayz
Mar 10, 2008
53
and go on by how you would do this can we get a step by step?
is250sp
Jan 22, 2008
26
wait, where are these 10 messages u speak of?
psylichon
Oct 31, 2007
16,591
751
41
Philly
etc.
Good luck!
Excellent. What format are those files?
Props on your name, too.
If you are using iTunes, I believe you can right click and convert the mp3 sound file to .aiff and then just rename it to .caf and over write it and it should work.
Always back up your original sound files first!
...and thanks, I get it all the time, it's also my xbox gamertag. :cool:
psylichon
Oct 31, 2007
16,591
751
41
Philly
AIF, sweet... that's easy enough. Thanks again, SOB! hehe
iconone
Apr 8, 2008
1,148
35
Clear Lake Texas
I cant get it to work i right click on a mp3 file and i don't see a option for .aiff. I am on a non jailbroke 3g and on iTunes 8.0. Do you have to jailbreak your 3g for this to work?
BigCiX
Jul 11, 2008
1,445
Bakersfield, CA
thats probably cause you have your folder options to not display the extension at the end of the file. Try this
using windows xp (not sure about vista but might be the same)
click on the following icons
- start
- control panel
- folder options
- view
- scroll down and uncheck "hide extensions for known files"
that there will give u the option to change the file to aiff
iconone
Apr 8, 2008
1,148
35
Clear Lake Texas
- start
- control panel
- folder options
- view
It was already unchecked. On the hidden file and folders i have show hidden files and folders checked and under that i have hide protected operating systems files checked 2. Idk anymore ideas? Im on xp
V.I.
Nov 17, 2009
Silly question, but is there any way for this to be done on a Mac? (also, non JB phone)
