Can I create folders in email?
Shlov1
Jan 12, 2009
42
I am trying to find out if it is possible to create additional folders in Mail. for example in my Comcast account, I've got my inbox and trash. That's it. How can I create additional folders. Then in my Gmail I've got a bunch more. Can anyone help? Thanks.
doron
Apr 17, 2007
1,141
tampa, FL
well, i know with gmail you can create folder on your desktop/laptop and will show up on your phone...
Quake97
Jul 10, 2007
522
Philly Burbs
It depends what method you're using. If you're using POP, then no. If you're using IMAP, yes, you can see other folders you've created.
Joe
cdelauz
Jul 13, 2008
291
Doesn't Gmail uses pop3 ?
28,365
5,507
You can use IMAP on Gmail, I do.
