Can i do anything if i forgot my passcode
tuckerbball
Jun 3, 2007
45
Ok today i was out to eat with my friend and i put a passcode on because i did not want them to mess with it before i went to the bathroom and then when i got in the car his little sister tried to get in it and i did not see her then when i got it back i could not remember the code and then i had to keep guessing and i got the time limited that it was disabled was an hour does anyone know how to get the code off without guessing and having to wait an hour every guess im so mad !
iPhobos
Jul 25, 2007
201
I am assuming you need to do a restore but I would check the Apple support site to see if there is some way around it. I am sorry bro good luck with that.
tuckerbball
Jun 3, 2007
45
Today i cheeked it and it sayed connect to iTunes and i did but when i did it say iPhone is passcode locked and it will not even sync so i don't no wut to do
liberated
Jul 19, 2007
3,237
487
I know what you should do....return the phone to the rightful owner and stop tryingto make us accessory to your theft! LOL
geordisjd
2,442
Restore and tattoo new password on forehead (backwards, so u can check it in the mirror)
Sep 28, 2007
Did you ever find out the master passcode?
iamtko
Sep 18, 2007
2,004
23
Houston
VERY NICE!
and to tucker, please use a period or SOME kind of punctuation.. that run-on sentence just killed all the english teachers out there :<
and i agree with the tattoo idea
TRIXX141
Jun 23, 2008
iPhone and iPod touch: Unable to restore
  • Last Modified: April 29, 2008
  • Article: HT1808
  • Old Article: 305797
Summary
If you have tried to restore your iPhone or iPod touch using iTunes and are unable to do so, try the following steps to force the device into recovery mode.
Products Affected
iPhone, iPod touch
Symptoms that may have occurred with an unsuccessful restore may include a frozen screen—either at the Apple logo or some other application—or the device may repeatedly reset.
  1. Verify you have iTunes 7.5 or later. Apple recommends using the latest version of iTunes.
  2. Disconnect the USB cable from the iPhone or iPod touch.
  3. Power off the device (Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPhone or iPod touch to turn off.
  4. Press and hold the Home button while reconnecting USB cable. When you reconnect USB, the device should then power on.
    Note: If you see the message "Charging... Please Wait" or you see the screen pictured below, let the device charge for at least 10 minutes to ensure the battery has some charge and then start with step 2 again.
  5. Continue holding the Home button while iPhone starts up. While starting up, you will see the Apple logo.
  6. When you see "Connect to iTunes" on the screen, you can release the Home button and iTunes will display the recovery mode message:
    If you don't see the "Connect to iTunes" screen, then disconnect the USB cable from iPhone and repeat steps 3-6.
Because you must restore iPhone or iPod touch, iTunes will not recover data from the device, but if it was previously synced on the same computer and the same user account, it should restore a backup (if available). See document 305744, "Updating and Restoring iPhone Software."
If you are still unable to restore the iPhone using this method, check Apple support for further troubleshooting and/or service options.
Note: If you sync both an iPhone and an iPod touch to the same computer, make sure you select the correct backup to restore your settings from (don't select an iPhone backup if you have an iPod touch and don't select an iPod touch backup if you have an iPhone).
SoccerSpartan20
Jul 4, 2007
32
oh wow, take a breath! i think my blood pressure rose by just reading that sentence. lol i'd try to restore it. You must've had quite the experience in the bathroom to lose the password in your mind so quickly :p
