Can I install Corona with Semi-tether already installed?
fijiman
Feb 13, 2011
832
64
UK
If you are still on a Tethered jailbreak...just run Boot Tether...then remove Semi Tether...then run Corona
iphonewarrior
13,847
699
It was not fine. I can't rejailbreak and I can't use mail or safari now. I'm stuck until I go home and restore/rejailbreak unless you can help me. After DFU mode, it says exploit failed.
Respringing your iDevice doesn't effect the tethered jailbreak. Something else must have been done to give you those problems.
What do you have installed from Cydia? My best advice after compiling about 3-4 different PM's into one message would be to restore your device and start again.
