Can i Keep my Contac list?
richiemd
Sep 8, 2008
hey um i hav a problem i jb my iPhone n i had catogories on it n had everything in a folder... then i backed it up to upgrade to 2.2 ... so it was good i had 2.2 then ... i use the back up n since my stuff wur in folders none of it showed up :S so am fuked now and i got to redo everything from the start the only thing am mad about is my contacts .... i have lots n don't wana rite down everything ones name n number to put it in again... is there a way i can just save my contactS?
15,385
1,089
you can save your contacts by syncing with iTunes, and making sure that the option to sync your contacts to your computer is checked (on the "info" tab on your iPhone page in iTunes).
When you restore, all of them should be synced back again.
