Can I make a ringtone from song purchased in iTunes?
spif91
Oct 7, 2007
101
11
NE Oklahoma
I have been making custom ringtones using iTunes for a couple of months now and am wondering if anyone knows a work around to make a R.T. with a purchased song from iTunes store. They seem to be mp4's and will not let me convert to an aac file when I right click on it. Is says this is a protected file. Any ideas?
Marianne
2,326
29
Massachusetts
marianneschultz.com
I think your only option is to burn it to a CD as an MP3 and then import it back to your library and then turn that MP3 version into a ringtone. You won't be able to do anything with the DRM version.
15,385
1,089
the simplest way is to burn them to a cd, and then import the CD into iTunes. this in effect removes the media protection from the .mp4.
edit: so yeah, what she^^^ said.
dturner
Dec 15, 2007
5,725
Louisville, Ky.
I use a cd-rw to burn protected single songs. This way you can erase the cd and use again.:cool:
spif91
Oct 7, 2007
101
11
NE Oklahoma
When I burn the playlist to a dvd-rw it still shows the files as m4p's. I imported the song back into iTunes and it still won't let me change it to an aac file. What am I doing wrong?
Marianne
2,326
29
Massachusetts
marianneschultz.com
Are you using iTunes 8? When you've selected a playlist to burn to a CD and the Burn Settings dialogue comes up, you must select MP3 CD for Disk Format. Then they'll be MP3 files when you re-import them to your library afterward and you can turn these into ringtones.
spif91
Oct 7, 2007
101
11
NE Oklahoma
My bad........I grabbed a dvd-rw out of the drawer by mistake and didn't have the mp3 option available........Got it....Thanks again.
redneck47441
Jun 3, 2009
120
Okay so yesterday I downloaded two songs that iTunes said could also be used as ringtones how do I apply them as ringtones when I go to my iPod on my phone their there under downloads now what?
Dakine
Mar 29, 2009
31
808
Do you have a Mac computer with garageband 4.1.1 or higher?
If so you are in luck, check this link on how to do it.
If you are running Windows you can find tutorials on Google to make then for free.
The last way is to make them in iTunes after paying an additional 99 cents to do it.
ki4ppg
Jun 11, 2009
9
or go to myxer.com and click the make your own
5,578
iRinger is free and easy to use for those on PC's.
tadaw07
Jun 26, 2009
84
phonezoo.com is free too..ive been using them for a while :laugh2::laugh2::p
