Can I restore factory settings without using iTunes?
EdmondT
Jul 6, 2007
11
Is there any way that I can restore factory settings to my iPhone WITHOUT doing it through iTunes?
I downloaded the new software for iTunes and the iPhone, and since that time iTunes does not recognize my iPhone.
It gives me a message saying that I should use the tab in iTunes to restore the iPhone's factory settings, but since iTunes does not recognize the phone, I can't do it through iTunes.
Anyone know how to restory factory settings just using the IPHone?
Thanks.
Edmond
hawkeye
Aug 4, 2007
Thanks.
Edmond
Go to your iPhone Settings -> General -> Reset
here you can select what sort of content you want to erase.. simple :)
