Can I unlock using iunlock from dev team on an inactivated iPhone?
abohsali
Jul 12, 2007
45
Hello,
I am considering the iunlock software unlock from the Apple Dev Team and was wondering if I can unlock the iPhone if it has not been activated with AT&T. If I buy a new iPhone can the phone be directly unlocked straight out of the box without even activating with AT&T. Thank you.
-Bohs
el31415
Jul 15, 2007
215
If you ask that question the only conclusion is ;
You didn't do your homework
and if I was you I will not try to unlocke it
better spent $25 and have someone do it for you check your local craiglist
by the way the answer to your question is yes
