Can I upgrade to iOS 7 and run Pangu jailbreak?
ring0_event
Aug 24, 2010
216
Hello. I have an iPhone5 still on 6.1.2. I missed the previous opportunity to jailbreak iOS7, and now my life is complicated by the fact that my suspend (aka lock) button does not work. So I make my phone suspend by using activator to allow double tap on status bar to lock my device. SO- this means that at the moment I CANNOT enter DFU mode! When I have time I will have to have my iPhone repaired, but I would like to jailbreak right away if possible.
My question is- keeping in mind that I cannot go to DFU mode at the moment, is it possible for me to upgrade to iOS7 and apply the Pangu jailbreak? Thanks for any help!
ring0_event
Aug 24, 2010
216
It seems the answer is yes, according to these videos:
I also REALLY need Activator to work well in order to lock my phone. It seems that Activator works for 7.1.1, but could anyone please confirm that Activator works for 7.1.2?
ring0_event
Aug 24, 2010
216
So...can no one confirm that Activator works fine on 7.1.2? I REALLY need this to lock my device, as my lock button is FUBARed!
ring0_event
Aug 24, 2010
216
I didn't JB yet, I'm still on 6.1.2. My lock button is BROKEN, so I can't suspend my device without Activator, hence I could not JB till someone confirmed that Activator works on 7.1.2- that, and I didn't get pkgbackup to work until this morning. Thanks for your answer!
28,365
5,506
Activator works just as well on 7.1.2 as is does on 7.1.1. It is not fully functional on either of them, but most things work.
ring0_event
Aug 24, 2010
216
Hmm...sorry if I ask so many questions, but since my iPhone5's lock button is damaged, I can't upgrade to 7.1.2 and JB unless I'm reasonably sure I could lock my device (and thus suspend it and save battery). I'm using Activator to map double tap on status (anywhere) to lock device. I'm *really sorry* to ask this, but If you (or anyone) could check if that option is available, I would be extremely grateful. I'm know I'm asking a lot...sorry!
28,365
5,506
I'm on 7.1.1. I can lock the device by double-tapping the status bar on the home screen, but not from the lock screen. I haven't been able to get any gestures to work on the lock screen since 6.x. I have it set to "anywhere."
ring0_event
Aug 24, 2010
216
Thanks Europa! I really appreciate the effort you've taken to help me, now I can JB to 7.1.2 tonight! Many thanks! :)
PS: It doesn't matter that gestures are not interpreted from the lock screen for my case, because there is a short timeout to sleep. I REALLY should fix that lock button, but meanwhile I'm free from the shackles of 6.1.2!
ring0_event
Aug 24, 2010
216
OK, I tried to upgrade from 6.1.2 to 7.1.2 in the latest iTunes, and I got the dreaded 3014 error. I think that I can reach gs.apple.com (17.151.36.39). Does this mean that I have to force my phone in DFU mode? If so, I'll have to repair my lock button before 7.1.3 is online. Or could there be another problem?
Jun 19, 2007
33,478
4,542
Upper Marlboro, MD
Do you have an altered hosts file? Are you using Tiny Umbrella? That will alter your hosts file and may not let iTunes verify the new firmware.
ring0_event
Aug 24, 2010
216
My hosts file is altered, just not for gs.apple.com. The IP address 17.151.36.39 is correct, no? I typed "ping gs.apple.com" at a command prompt, and that IP was queried though there was no response (not surprising, ping is probably not enabled). That IP is correct no?
Jun 19, 2007
33,478
4,542
Upper Marlboro, MD
Try commenting out that IP and try it again.
ring0_event
Aug 24, 2010
216
Yes, it's commented out, but no go. Any ideas? I can't put my phone into DFU mode atm, and I'll try to have the lock button repaired this weekend. But till then, any other ideas?
28,365
5,506
Install TinyUmbrella and uncheck the box that says "set hosts to Cydia on exit." That will fix and problems with your host file.
ring0_event
Aug 24, 2010
216
Hi Europa, thanks for your reply. I don't *think* that there is an issue with my hosts file, because when I ping gs.apple.com from a command prompt, the IP address displayed on the screen is 17.151.36.39, which is not Saurik's server. In any case, I have commented out all the relevant parts of my hosts file by placing a "#" before it. I've even tried deleting (well, renaming) the hosts file, so I truly doubt that this is a hosts file issue...
28,365
5,506
The troubleshooting for that error is to fix the hosts file, update iTunes and temporarily disable antivirus software and firewalls. If all of that fails, try another computer.
ring0_event
Aug 24, 2010
216
Thanks for your reply, Europa, I'll see what I can do.
ring0_event
Aug 24, 2010
216
One question, Europa: say I manage to update to 7.1.2 on another computer. Do you think it likely that I'll be able to restore my backup at home? In other words, can my spurious 4014 error be triggered by this process, or does it only happen for the application of a new firmware?
28,365
5,506
You can apply your backup at home as long as it's an iTunes backup and not an iCloud backup. Instead of selecting the restore option, you will right click on the device on the left panel and select Restore from Backup.
