Can I use a blackberry SIM card in my iPhone?
gotendbz1
Jul 15, 2009
This has been answered before probably but i couldn't find anything in the search.
I have a blackbery curve from work with the bb data plan. I just got my hands on a 3G. If i put the sim card from BB into iPhone will it work?
I read that att/Apple lock your number to each iPhone and you have to activate it for it to work?
any info would be great.
dturner
Dec 15, 2007
5,725
Louisville, Ky.
This has been brought up before and if I remember correctly, it will work. But I believe you will not have VVM. If I remember correctly, this works but an iPhone data plan won't work on the BB.
Someone will correct me if I am wrong.
rojocrandall
Mar 2, 2009
424
dturner is correct. After installing the sim, you can activate your iPhone with iTunes. BB data plan is not compatible with iPhone.
jbw52
Jun 16, 2009
I just added a line for my stepson and gave him my BB. At the same time I got a 3G for myself. Instead of swapping SIMs they kept the SIM in the BB and reprogrammed it for the new number and gave the SIM in the 3G my old number. So I am guessing that if that is the way they do it at the ATT store, then the BB SIM probably wold not work in the 3G. After all, it would have eliminated a step for the person setting up the account to just swap the SIM.
rojocrandall
Mar 2, 2009
424
Hi jbw52.
Actually, by leaving the SIM in the BB, the ATT clerk saved a step.
I have a 3G and my wife a 8310 Curve. To confirm, I swapped SIMs and
had my daughter call both phones. My # rang on the BB, my wife's on the iPhone. So the SIMs are definitely interchangeable.
Saverino
Jun 1, 2008
4,480
92
Burbank
AT&T does NOT switch your data plan without your consent.
SIM cards from a BlackBerry will work just fine in an iPhone.
iPhones that are running 3.0 and using a BB data plan won't have data access, but there is a way around this.
gotendbz1
Jul 15, 2009
any chance you can explain? will this incur any additional charges?
Jul 18, 2010
putting a non iPhone sim card into a iPhone
OMG I am having troubles... I had a bb and now i have a iPhone 4.0.1. i called and switched to my iPhone, and even changed my data package to iPhone so i should be all good to go right? wrong. the phone and texting works but i can't use the internet. AT&T said that i can't use the old sim card that i have to purchase a new one because u can't do it. I am really not computer smart and don't know if there is a way besides going and buying a new sim card for 25 $..
